Antenna pucks? What are and what are their use?
CrashRecovery
62
92
28
48
So in my search for knowledge on antennas it has been brought up to try a setup using a NMO Puck from breedlove. I'm still unsure what they are there for. I can understand if they are used to prevent damage to the roof from a standard NMO connection.
It was suggested I use a puck and a Larsen NMO style antenna. So what do I gain from using a puck?
I beleive the main gain is the best possible grounding contact you can get. The drawback is to achieve this you must drill a hole in your car/truck, pull the headliner and do a little welding. If you still owe on your car/truck you might not want to go that route. The resale price may also be affected by having a hole drilled in it, another angle to think about before pucking. If you want to run power it's really the best mounting option i think.
I haven't found anyone’s who has had a problem at sale. If it’s a worry, install a cell phone mount and cheap antenna. My father Buick’s and Cadillacs going back to 1962 had baseload for radiotelephone on rear fender top at rear glass corner.
Haven’t seen welding. The puck type features thru-bolts.
Maybe someone can link the Breedlove video on how to install.
Just remember when you buy a chassis punch, don't buy one for 3/4 pipe, make sure it's to make a 3/4 hole because there's a difference. Or else you'll end up with an oversized hole you can't do anything with. A radio chassis punch is what I've got (pictured)
Reactions: Slowmover
