The counter is used by antenna (*edit to add* counter antenna close to radio antenna), I only talk on LSB so assuming they're on 27.3840 and I'm on 27.3843, is that .0003 enough to cause the issue?
It just may be the "Error" seen in the Frequency Counter - including leads and all other stuff combined.
The bigger picture is to know that you sound good - on frequency - to them - that is far more important than any frequency counter. You let them be their "center slot" even though you may have to tweak yours to obtain theirs - don't worry about it - focus more on having a conversation - it will get easier with time and number of "contacts" made.
Its' just better to relax and let experience take the lead in this - don't focus so much on "frequency", QSO's are more of the operator your want to contact - not being on their "center-slot" - wait until winter really hits, you'll know all about drifting then....
Relax Luke - you'll be ok, you'll do fine.
Let the Force flow thru you -
Soon, you'll be blowing away the competition
...Figuratively speaking - of course...
If you already have a frequency counter just pick up a BNC to test lead set - they are like $10. Once you have that you can do the alignment using the test points inside the radio and get everything lined up spot on without any guessing.
Once you learn to do that you can do it on pretty much any radio in a very short period of time. Then your friends will be lined up to have you align their radios
Funny story on this topic - there was a group of 3-4 SSB regulars in an area when I first moved there and I was the new guy and had a brand new RCI-2950 and they mostly had older radios and every time I went to talk to them they were all off freq to me, they all told me my new radio had a problem and must be off. A couple of days later DX rolled in and everyone I heard and talked to was on freq and those 3-4 guys were off and telling other people they were off. Turned out the other guys had set their radios to the guy with the big radio but his radio was off so they all ended up off![]()
I had to google that.....looks like it mainly applies to CW comms?Zero beat?
If you are careful and listen for the zero beat between the rx radio audio output and the audio generator (you will need to make the audio generator audible in some fashion) you can get within a few cycles of the tx radio's frequencyThe title is my question. Is this possible, at least in theory? While I do understand the extreme crudeness of this idea, I can't help but think it's possible with somewhat decent (not perfect) results. With the clarifier on both radios in the center position, using the known good radio and an external 1K tone through the mic transmit and adjust 2nd radio RX pots until it is clear on the receiving radio. Then transmit the same 1K tone on the 2nd radio and adjust 2nd radio TX until it is clear on the known good radio. I'm asking this as a no other option, no techs, no equipment, kinda question.
Thanks for any input.
