Well, by your chart, I don't see anything "wrong" except the ones you highlight are for the Channel Selector - Are you on Channel 9 or 19?
By your pinout measurements, you're running a bad channel selector - Pin 9 goes "high" to "WASH OUT" the input - this keeps the internal logic on "hold" until either it's in lock, or your have the right pins getting set so it can divide for CB channels.
Pin 7 is the LO from L15 - if it's not "ringing" it tries to force the Varactor loading higher to raise / change the capacitance to start the ring. (Your TP1/2)
Pin 8 is the EXTERNAL detect - it looks at the Microphone Jack Pin 3 - if it rises or falls - this tells the PLL to "follow" that status - so it will push power into Pin 7 - or remove it to make the PLL Shift - once the PLL sees a "lock" - Pin 9 takes over. This is where the PLL will allow you change the channels (In RX Mode) or when in TX - the 455kHz Shift takes place and you see two IF's mixing to make the 27MHz at IC2 - else TP3 - you see a 455kHz offset "change" in RX to TX and Back again.
Pin 9 "looks" at the LO VCO - but if the pins are not set right - it ignores the input -won't do anything - so no output.- sets this high to wash its input.
So your better options to even see if it could "fire" is to run the CH 9 switch ON - until you figure out the BCD encoding. At least override the BCD or even remove the cable and assembly - then set the pins manually. IF it works then you have the culprit in your hand - the selector is out of whack.
- No radio is perfectly bullet proof. - I've seen BCD encoders - from Brand New out of the box radios - being BAD, due to someone "faceplanting" (Dropping) the radio on the channel knob - breaking the wafers inside
