WTB - Galaxy Expander "N" kit
The Expo 100 "N" kit is basically an "A" with varactors added to the crystals. It does not compensate for mode selection, you would have to open your Clarifier and shift either 2.5 Kc up or down to get back to center slot.
A Galaxy Viagra board works better, The Viagra A board has individual adjustment coils on each crystal for the 3 modes, AM/USB/LSB.
The Viagra B board has an MC145106DM surface mount PLL on it, and has it set up to step in 2.5 Kc steps on the lower pins of the programmable divider for mode selection, and uses diodes to add to the 4008 adder chips for band selection on the higher pins of the programmable divider.
I bought a few from RF Parts about 2008 or so before they discontinued selling them, for samples,
I bought a couple of "Blue Dot A" boards (+40, -40), put one of these in my PC122 to test (still in it), a "Green Dot A" (I forget, maybe +40 and +80 ?) and "Red Dot A" board (I think -40 and -80). These boards are all in my storage unit, buried right now.
I also bought a "Viagra B" board, the one with the PLL on it, never installed it,
https://www.worldwidedx.com/threads/realistic-trc-465-vco.257429/#post-731836
Reactions: tecnicoloco
I wish he'd include some sort of "daughter" pc board to plug the Arduino nano into. The holes around the edge of that board are okay to insert and solder just one wire. But the ground and power pins end up pretty crowded with wires leading off four or more directions.
Cool firmware, though.
Reactions: NZ8N
    boog351 has left the room.
