First, my antenna tests. I tried five antennas. A 4' Fire stick 2, a 4.5' Procomm quad wound with tunable tip, a 5 ' Skip Shooter, a Hustler "beer can," and my old trusty Wilson 2ks.
Three top loaded vs two center loaded. Two positions, and one cophase setup. The best ears went to the cophased W2ks, the best transmit went to the PC qw. The easiest to tune was a tie between the PC qw, and the FS2. My least favorite was the Hustler. The SS was OK, but is running 1.1 across all frequencies, which from reading through posts, and the ample info shared with me from past threads, is not a good sign. The W2ks, although cophased, had the best recieve, and remarkably so, the transmit was a bit weak. They do tune pretty well though. I may now try a P10k. I still like the ears of cophased antennas, but that PC qw really got out there. The single setup ears were not to great, inspite of the claim that the qw top load would have recieve gain, due to the increased signal capture area. Maybe a cophased setup? The SS though was disappointing in comparison. The 1.1 had me initially "excited," but the needle didn't move across all channels, and bands.
Second. I was thinking of grounding my radio. Does it help? I ask, because I noticed that static increases, and Audio decreases when I hold the Ranger mic. When I set it down, the static decreases, and audio increases. When I swapped it out with my TopGun 56 (old style RK 56,) there's no static increase, but the audio level is less. A problem with the new Ranger mic, or just my body acting as a capacitor, causing an issue? Why only with the Ranger mic?
Thanks.
Thanks.
