Stryker SR-25MC
i like mine,, have it in my 2001 blazer fits just right on the right side of steering wheel, i little tough on set up but a slight mod and it does 10/11/12 meters am/fm at ten watts ,, i dont use a amp with it just a wilson 5000 usa made not china junk,, yes it is a older antenna but one i have had for years,, the antenna is hard mounted in center of roof and every one here says it gets out good,, midnight special cbt 273 central florida,,
Reactions: Eldorado828
I second @midnight special
I bought one a couple of years ago and just recently put it in place of the 6666 in the daily driver. For the cost, you get quite a punch and features in a tiny little radio. It's the big
anytone mini me
It works as good as or better than some of the huge big chassis radios available.
I bought one a couple of years ago and just recently put it in place of the 6666 in the daily driver. For the cost, you get quite a punch and features in a tiny little radio. It's the bigView attachment 57932 anytone mini me
That's good news. Thanks! I will not be using an amp because I think the stock radio will work fine with the steel whip antenna.
Reactions: midnight special
What is the lowest RF power output?
