Sorry, I failed to mention, I replaced it.try removing the transistor and testing it.
the problem could be the component itself.
NZ8nSo, putting everything else back together, center pin (Collector) of TR21 soldered too, the RED LED stays on or goes out (switches to Green) when you lift one leg of R95?? Or merely unkeys the radio, RED LED still on?
That feeds +8v TX to the output pin of the Mixer section of IC3 through L21.
Thanks for that. And FYI all 3 legs of TR21 are w/in .1v of 8 volts at all times.Something is "pulling" the Base of TR21 down just enough to cause it to "key" and light the red LED. Half of the Receiver circuits are "fed" from the voltage at the Base of TR21, when you key (TR7, FET1, Base Bias of TR10 in the 2nd IF, maybe a few other places), it shorts nearly to Ground the voltage that feeds them. It also "feeds" the Emitter side of the Mic Preamp, and a few other places. It also feeds the "high" side of the Delta Tune pot.
When I get home, I will dig out a schematic diagram I "drew" on, tracing out the RX and TX paths that spider from TR21. Or redraw it.
I can do that when I get back but the transistor works. I swapped it with another radio with no change. The other radio works fine with the transistor from the nonworking radio. I can’t recall those voltages off the top of my head but I believe the trace for the collector, middle leg, was around 12 V without a transistor in place.remove TR21 again and measure the voltages on the empty traces.
everything you are saying sounds like a shorted TR21 so we need to see what is going on without the transistor there.
my apologies for the statement "everything looks like a shorted transistor".
I should have looked at the voltage chart before guessing, as i would have seen that your voltages look correct for TX, and the problem is that the collector of TR21 is not dropping to 0 volts on RX.
here is a voltage chart that includes IC3, your TX mixer chip.
please check the voltages on all pins of IC3 in both RX and TX and post them here.
Red is direct PTT, (through R101, 2.2 Ohms), which also "feeds half of the RX circuits. Orange is path after D21, R70 to C67.
NZ8n
Everything back to stock: Radios stays keyed up. Red TX light is on.
R95 lifted: Radio unkeys (no rf power output) but red TX light still stays on.
Actually, he said it quit transmitting, the red TX LED stayed on.
Have you recapped it yet?
Unsolder one leg of R70 (330 Ohm) first, (don't cut it, geez!), if you get RX and Green LED back, C67 is shorted. C67 goes "through" R70, then through the cathode of D21. These feed the Mic preamp bias (Ground side) when keyed.
If C67 is "shorted", it might have enough "pull" to turn TR21 on.
The Emitter of TR21 should have +8v constant, the Base of TR21 should have +8v when unkeyed, and nearly +8v, maybe 7.3v when keyed. The Collector (center leg) should only have +8v when in TX (also turns the Red LED on).
View attachment 58941Red is direct PTT, (through R101, 2.2 Ohms), which also "feeds half of the RX circuits. Orange is path after D21, R70 to C67.
Locations of components I think may be affected. R70 and D21 are most likely ok.
