Parrot Box for CB
Alexis Mercado
Well-Known Member
May 17, 2016
404
248
53
50
Hi. I am in search of a “ parrot” box for a Cobra CB radio. I think it’s official name is simplex repeater. When someone transmit on a channel where this “ parrot “ is connected, it repeats exactly what you say. It has some kind of a recording device. It can records several seconds and then, this parrot box activates radio PTT.
Anyone know where to buy such “parrot “ box ?
Check for a Peat Repeat or Watergate recorder. They are installed inside the radio and there is a small red and black button to control it.
Alexis, are you looking for a " simplex repeater"?
Do you want to record audio and play it back, or are you wanting something you set up with a radio, it receives a signal, records it and then activates the ptt on the radio and plays it back over the air?
Not sure what you are looking for.
I want something to set up with a radio to receives a signal, records it and then activates the ptt on the radio and plays it back over the air
Those are really aggravating Those are really aggravating Those are really aggravating Those are really aggravating
LOL right along with noise toys and aftermarket roger beeps
Reactions: Greg T
They are useful if you place them at a high level to get to areas that you are not able to reach directly.
Example.
User down in the valley, repeater radio at 7000 feet elevation, user down on Huntington Lake.
You could never reach the lake from the valley, but the repeater can easily hear both.
This is a very simple , simplex, record and forward repeater.
    boog351 has left the room.
