Cobra 148 GTL power issue
Crambone
Well-Known Member
Jan 22, 2019
563
175
53
58
Friend dropped off his 148GTL for me to look at as he wired neg and pos backwards. I checked main fuse on the power wire and it had a 10amp blown in it!! So my first guess was D55 and I found it shorted closed not open. I replaced and still nothing but I’m seeing 12vdc everywhere in the radio even places I believe it shouldn’t be?
Any suggestions where to take a look?
1st thing i would do is use like a 1 amp fuse while trying to find the problem also check the voltages at the mb3756 regulator at pin-2 the wrong amp fuse was put in there which caused more problems compared to just the fuse and d55 to blow with way fewer problems
there is (by the transformer) another (glass looking) diode next to it.. replace it.
Reactions: Crambone
