Wilson 5K load on a Wilson 1K mag mount (RG58) on a 2 by 3 foot metal table on porch 15 feet off the ground used with a K40 / 58 inch stinger (because it "appeared" to match better then the Wilson's) I'm guessing RF is traveling the outside of the coax because moving wires , radio or coax inside can effect the SWR drastically , left in one place around the cb and free brands "appears to look good" Was using a SWR bridge and it would give me one reading but the radio (AT-6666 at full power) would give me another , just seems like everything is a part of the antenna .
So I just decided to use the radios SWR meter for the mean time . I can stay way below 1.5 not moving anything but it can waver a bit because I think I'm also a part of the antenna . I'm guessing what I'm seeing is a false reading for say ? but it does talk with pretty good radio checks. From what I have read it looks like I have grounding issues ?
I have tried to coil some of the coax next to antenna and that only made it worse and tried a ferrite clip-on and it only did the same thing , problem being there really isn't much to ground it too , the porch is only 10 feet by 6 feet or so , there is a electrical outlet about 8 feet from the mag mount and a tin or aluminum gutter that goes down to the ground to drain water. Condo living doesn't help much with rules and regs as they are. Any suggestions would greatly be appreciated. Thanks
