Galaxy N kit
dss56
Well-Known Member
Sep 27, 2010
434
125
53
57
Has anyone seen these kits before? Im trying to get directions for install in radios.
It says can install in a cobra 29. Kit has 4 wires thats all I know.
Shows many more radios. The board has no xtals on it so
wondering how this kit will work?
And comments appreciated
these kits show 2 ic chips no xtals and 1 cap. so just wondering how it would work on a cobra 29 when you have to inject a signal to the mixer stage. Expo 100 A kits
I saw that logic chip board info somewhere, I think in Secret CB, I'm looking now.
ok thanks fist i ever saw this and trying to analyze how it would work or the directions are wrong for this to work in a cobra 29 or any of the radios i showed the list on.
The person selling keeps avoiding sending me a picture of the install points on a cobra. So he says you cut 1 pll pin and put 1 wire on each side and thats it. Still wont send a picture but verbally said how its done
ok thanks fist i ever saw this and trying to analyze how it would work or the directions are wron for this to work in a cobra 29 or any of the radios i showed the list on.
It lists the 29 GTL, not the 29 LTD. They are different boards.
29GTL and 29LTD are different boards, but similar design, same PLL (uPD2816). GTL was the precursor to the LTD's.
Reactions: tecnicoloco
It looks like it hijacks the 5.12 MHz (10.240/2) output signal from the PLL Pin 10, runs it through some loopy logic chips, that add either 320kc to the signal. or 640kc to the signal.
A 7493 4-bit binary counter and a 7400 quad NAND gate.
On the Cobra 29 (GTL/LTD etc...) you would pull C94. This comes from the 5.12 MHz output of the PLL, before it goes to the tripler coil L22.
    boog351 has left the room.
