Ok once again...
Slugs...note one is
aside from crap on his desk
It's this I question...
Ok, span of 52MHz but Visible Bandwidth of 1MHz - only shows part of a bigger window...
This is the output of his
SIGNAL GENERATOR - the radio we cannot prove
in TX mode...
Because If he's showing this...
And you get that...(His PEP?)
Wow, ok, more than a 4:1 ratio here...but to each his own...
Further into the video...what else shows up - or should I say that same thing all over again and I can only presume the mode and method are still the same - Radio? Can't prove this reading setting either...
Now I see 80 watts...Average? Can only presume radio and mode (SSB)?
Again...look carefully...
on his PEP meter...
What I cannot understand is the SAME Reading from different modes...
I can only deduct that the radio is not tuned up - it's over peaked. Meaning 150 watts of PEP if he calls it that simply is showing harmonics, distortion and who knows what else...
Now the envelope shows mishmash...no cutoff - was he in FM mode(?) - looks like it to me...
He shows us a spectrum analyzer, with a nice tone, but we cant prove if it is or not the radio under test doing that...was it transmitting...or receiving...?
150 watts PEP - all the same readings - from whatever that meter is being fed from - and again, with all the crap on the desk, we have no clue if that signal is from the 6666 or something else...
And he's throwing all of this into a spectrum analyzer - in limited bandwidth - see arrows - RBW Receive Band Width, VBW Visual Band width - Gratitude scale of 5MHz but doesn't match - looks like it's zoomed in...
Have fun...
