Another Anytone clone from Radioddity Qt-60
It definitely looks like a clone!
But, is it just a Anyone manufactured, with the Radioddity name on it? Similar to the CRT 7900?? Re branded, Or is it a true clone? A knock off..
That's what I'm curious about.
i want to know if they do any kind of alignment (modulation-wise), or is it just a re-badge?
18 month warranty sure beats 0 month.
I'd put money that it's straight from the factory with their name on it. They're nice right out of the box which is one thin setting it apart from the other.
"Frequency tuning step: 100Hz, 1KHz, 5KHz, 10KHz, 100KHz, 1MHz"
is the 5KHz steps for Amateur bands? manually tuning (VFO?) clicking the tuning dial, i've only been able to do single digits on the AT-5555N II.
[EDIT] i've found 'Step' in the menus. set it to 5K but it still doesn't work.
I forget what I did exactly other than it worked. The radio no longer on the bench in front of me. Try to choose 10khz and see if that works. There might be a step to ensure the changes made are saved?
Pez will know what to do when he reads this... Pez....? PEZZZZ?
  • Haha
Reactions: Pez
Looks like the Radioddity qt-60 is available now @ $357 on their site.
73s
Why would you think that? True amateur HF radios do not tune in steps but rather in smooth, usually 10Hz steps. The frequency display may only read out to 100Hz but the processor usually tunes in 10 Hz steps. 5 KHz steps is a CB/freeband thing. On the amateur bands a frequency of 28.573.8 is perfectly valid.
  • @ Spanish:
    Where do i upload schematics
