If you are following the instructions included, that is for 10 m. start with 22.5 feet from where the coax screws in to the tip and fine tune from there.
True, we was trying everything. The second picture of the same was the second SPT-500 after we took the first one back. Both are NIB.Looks like someone tried to bend that flat strap to look like the wire part on the original SPT-500.
As we are hams, We tried all the way out, and all the way in... same, both new antennas from DXIf you are following the instructions included, that is for 10 m. start with 22.5 feet from where the coax screws in to the tip and fine tune from there.
we are ham.These instructions show 19' but that is for Ham band. Mine ended up 22' 8 3/4" for 11 meter.
Please read my original comment on this thread. 28.4 Mhz is MY goal.For a 23 channel cb the oal of the radiator is 22' 9 1/2"
for a 40 channel cb the oal of the radiator is 22' 6"
Factory specs there.
Did you try shorter than 19'? My records show 10 meter goes up up to 28.305 mhz. When I get my house finished I will start on the Ham journey.Please read my original comment on this thread. 28.4 Mhz is MY goal.
10 Meters covers 28.0MHz to 29.7MHz, he wants the antenna to be centered at 28.4MHz.Did you try shorter than 19'? My records show 10 meter goes up up to 28.305 mhz. When I get my house finished I will start on the Ham journey.
Did you measure the overall length of the antenna at 33-34 MHz, it had to be shorter than 19'. It would just be interesting to know......Three Extra class and a General class operators with tons of experience could not tune this antenna. Length of vertical , length of radials could not get to resonate anyplace other than 33-34 Mhz at 1.3 SWR and 68 Z. It was replaced at DX Engineering with another one today 9/13/23 .... long story short, it did the exact same thing. Top insulator long side up, radial bracket flat against the mounting bracket. MFJ 259, Rig Expert, and NANO VNA, different types/lengths of coax was used. Looking for someone that has experience the same with the fix. DXE? no help...Hy-Gain , No help, They say we put together wrong? Two in a row?
Thanks for the Education. I guess My frequency info is outdated.10 Meters covers 28.0MHz to 29.7MHz, he wants the antenna to be centered at 28.4MHz.
28.305MHz is where the phone part of 10 Meters starts.
It's not gamma. It's a beta, or a hairpin match. I have one here,, they claim the Hy-Gain design was subject to breaking, so they changed it.Has anyone seen the new gamma match for the super penetrator? Why did they have to change it?
I thought it might be cheaper to stamp it out/It's not gamma. It's a beta, or a hairpin match. I have one here,, they claim the Hy-Gain design was subject to breaking, so they changed it.
