Drew,AM is working perfect but on LSB & USB if I have the RF Power more than 25% when I key I’m seeing a full carrier? Receive sounds good on both LSB and USB.
Drew
Thanks I will check that, I had the microphone gain all the way down and tried also I will look at VvR7Drew,
The 2 things that come to mind is the background audio is too loud and causing transmit power or the carrier balance pot (VR7) is not aligned.
