My Old K40 rides again !
FlyBoy50
Radio 75
Feb 22, 2019
2,549
4,165
273
76
Retired my Astro van because of too many issues and pulled my K40 off the roof. Was the longest antenna I could have on top because of all the trees around here. Well decided to try a Tram 3500 on my new ( used ) Ford Expedition because I had so much luck with one on my Chevy Cobalt. ( about identical length as the K40 ) Well installed the Tram 3500 4 days ago and couldn't get a good SWR no matter what I tried. Well today was going to a nice spot for installing and checking SWR on a antenna so put my old Tried & True K40 in my Expedition. When I got my work done I swapped out my Tram 3500 for my K40 in the same exact spot and climbed inside for the SWR test and with out any adjustments I got 1.1-1 on channel 1 & 40 and on channel 20 I got a Flat Liner ------. WOOO HOOO talk about a happy camper. Now it will get me excited to hook up my KL-200 P when I figure out how to tap into the power source. Makes me think maybe I received a bad Tram 3500. Any suggestions on testing it without spending a fortune?
NanoVNA would work. Not free, but you can find it for under $100.
Searched for it and looks like it is beyond my technical training and cost more than the Antenna it's self. Cheaper to Bail the Antenna. LOL
Just a heads up, the K40 has a ceramic matching capacitor inside the coil base and it will not like your KL-200p power, will probably burn out sending swr through the roof and possibly blowing your amp. They were designed back in the days when CB radios were just 4 Watts. Great little antenna but I would check its max power handling before you hook up your burner.
Reactions: FlyBoy50
Will Do Thanks I have made contacts with the K 40 and the KL-200P but maybe I just got Lucky
I seem to remember I was fine at 200 pep watts w the k40 but when I put a 4 pill inline kaboom. I smoked the K4O.
I also replaced it with a Wilson 1000.
Still have it in the garage somewhere.
I think that K40 will be fine as long as you're easy on her.
Reactions: FlyBoy50
I can't remember what the K40 is rated for. I'll have to recheck again but I do know I used the KL-200P with it and made contacts but it hasn't had heavy use so I will be ware.
Reactions: lonestarbandit
Thanks The KL-200 sure won't do that !
No. I think you'll be fine with that pairing.
I loved that old K40. Great ears and the twist remove was perfect for carwashes and avoiding theft.
I seem to remember I lost a little on the ears going to the Wilson.
I bought a Wilson Lil Will one time and couldn't get a good SWR with it so it soured me an Wilson so I went to Tram with good results on 3 of there mag mounts. But the 4th Tram 3500 I'm having problems with. It might be the Law of Averages is catching up with me. LOL
