I see Shadetree has done his research while I was posting.
Radio transmitters are not as anonymous as people think they are.
My point is that the authentication doesn't use rise time. I don't intend on paying to read the first link, but the second link talks about adding intentional phase errors. Obviously, if a system is designed with fingerprinting methods in mind, great. But you are not identifying a transmitter on the rise time of the signal alone. And none of it pertains to CB radio.It's a good thing that they cited references.
Improved Radiometric Identification of Wireless Devices Using MIMO Transmission
Authenticating wireless devices based on features of their transmitted waveform has become a topic of considerable interest. Recent work in this arena has shown that examination of features in a modulated waveform can lead to highly precise identification of 802.11 devices. This paper...ieeexplore.ieee.org
Stay Connected, Leave no Trace: Enhancing Security and Privacy in WiFi via Obfuscating Radiometric Fingerprints: Proceedings of the ACM on Measurement and Analysis of Computing Systems: Vol 4, No 3
The intrinsic hardware imperfection of WiFi chipsets manifests itself in the transmitted signal, leading to a unique radiometric fingerprint. This fingerprint can be used as an additional means of authentication to enhance security. In fact, recent works ...dl.acm.org
None taken.No offense to licensed idiots out there BTW.
It is absolutely NOT BS ! The information in post number 24 is correct. All radio transmitters do indeed have a telltale signature based not only on 'rise' time, but also on the frequency offset, AC ripple within the transmission, and a number of other detectable parameters.I'll call BS on post #24 too
I am not disputing that there are characteristics that make a transmitter unique, I am merely stating that rise time, the subject of post 24, is not one of them. I also noted in my post above that it is more likely that they would use spurious emissions as a fingerprint, and what Mike just said supports exactly that. At S3 (-109dBm), most of the spurious emissions that are supposed to be at least 60dB down start to climb out of the noise when the carrier reaches S3.It is absolutely NOT BS ! The information in post number 24 is correct. All radio transmitters do indeed have a telltale signature based not only on 'rise' time, but also on the frequency offset, AC ripple within the transmission, and a number of other detectable parameters.
Now that said, the chances that the FCC or any other countries radio authority is actually tracking people on 11 meters using this technology is very slim. However, if they really want to they can !
That is one of the reasons I have an issue with today's exam structure. A total idiot can get their license with a couple hours memorizing answers to questions without having a clue as to why the answer is as it is. No offense to licensed idiots out there BTW. IMHO there is NO excuse for not knowing your band edges even on your first day on the air.
I guess they still do have the classesWhen I had interest in being a ham, there was a club in Las Vegas that held a class at the Air Force Base. Nellis Radio Amateur Club (https://nellisrac.org/). It was a several weeks long and went through the Tech handbook one chapter at a time and explained every aspect of the chapter being studied. Not sure if they're doing that any more.
I don't see any clubs doing that, but the opposite in what are basically cram sessions to get you through the exam, which may be fine, I'm not judging.
nellisrac.org
This is the correct answer. Each radio has a unique 'fingerprint' based on a bunch of technical parameters including, but not limited to, rise time, AC ripple, frequency drift, freq. offset, bandwidth, harmonic content, and others....."this is the same radio that was transmitting 2 days 3 hours and 42 seconds ago on this frequency"????
It varies from club to club. One local club here holds sessions similar to what you described, with a couple months theory and regulations and even a CW course, even though it is no longer required. Other clubs are into it for financial gain only and offer cram sessions where you simply ;earn to memorize the correct answers to the questions and end up passing without a clue as how those answers were derived or why.When I had interest in being a ham, there was a club in Las Vegas that held a class at the Air Force Base. Nellis Radio Amateur Club (https://nellisrac.org/). It was a several weeks long and went through the Tech handbook one chapter at a time and explained every aspect of the chapter being studied. Not sure if they're doing that any more.
