Any Idea Why Icom Not Properly Accessing "Wouxun DCS Codes" ?
Wire Weasel
Senior Moment
Dec 13, 2008
3,279
948
223
Hi guys, In my area we have a Group-Owned Linked GMRS Repeater network that covers a huge area. Some of the machines use PL tones while a few use the so-called "Wouxun" CTS tones that read like D023N - which is Code #1 on the list. The repeater nearest me is one that uses these stated tones. I have a China HT whose CTS tones are in the menu like this and it keys the repeater just fine .... I'm not far away from it. Now my Icom 2730A dual band mobile has only the plain numbers for its CTs and it says only 023 (for code 1) without the letters. It does have 4 options for modifying the "polarity" of the CTS codes and I have tried every one of them and still the Icom will not activate the repeater. Any idea what is going on here or what I'm doing wrong? Thanks!
The "N" is a Negative or REVERSED DCS code. If the Icom does not support rev DCS, you are out of luck. If you are able to duplicate the code using the polarity modes, you want to look at the DCS deviation of the Icom. Can the radio decode?
I have it set correctly now, thanks! I had selected the correct DCS Reverse Sub-Function but didn't lock it in correctly.
