Cup Holder Radio Mount
Recon
Jul 28, 2019
1,300
1,443
173
Sharing my Home-Brew project.
Try this for installing a small radio in a tight area.
LIDO Cup Holder Mount with a Uniden PRO 510XL. I removed the speaker to install the mounting plate to the speaker grille and reinstalled the speaker. Using the bottom cover (speaker side) to mount the mounting plate eliminates the need to use the factory radio mount bracket and also provides more contact surface.
