NEW RM Italy BLA 703 Base Amplifier
The original "batch" which was released back around February of this year, and was only sold to European and other countries AND continents where (of course) FCC approval is NOT required.
The latest "batch" which just arrived in America on November 1st, is in fact, FCC approved., and required many months and many $$$$ to make it so...
I've been friends with, and telephoned with (on MANY occasions since 2010) both the lead-engineer (who is British) and the owner (Italian of course) of the RM Italy facility (founded by his father)., and if you had taken the time to even lightly peruse / read the article-links provided in this thread so far., you would have seen that I was just at their facility for the "complete tour"., last month on October 23rd :)
The amplifier that I display in my articles, was sent directly to me by the RM facility (about 4 months ago) and was (of course) part of their 1st batch for the European / world-wide market, and therefore (of course) does NOT display an FCC number on its back-side.
Now you've switched the subject to comparing a factory-manufactured, "turn-key", automatic band-switching, 1.4 Mhz to 54 Mhz, all-mode linear amplifier (ie: the BLA-600)., with that of something which would be part factory and part hobby-craft...
I never said the RM-3 was a part number, and actually went out-of-my-way (again, if you would have taken the short time to peruse / read the attached / linked articles I had written)., and would have seen where I explained that the RM-3 MOSFETs are "scrubbed" of their actual part number AND as to why they are :(
I also explained as to why just a few of their amplifiers (less than 10%) utilize the MUCH less expensive, TO-220 case-style MOSFETs instead of VERY expensive / actual RF-devices., which ARE utilized in the other 90% of their amplifiers.
Again., this new 2nd batch, which just arrived in America on November 1st., is in fact FCC type-accepted, and do in fact have the appropriate "FCC ID number" affixed to them.
One must just have the time and patience to read AND humility to investigate a matter-of-concern BEFORE passing judgement...
BTW: Did ya even take the time to peruse / read the attached PDF file of the owner's manual, which supplies at least three illustrations (of which most other commercially built amplifiers do not) and covers the subjects concerning the following:
1: Linearity (power in versus power out) on page #8
2: Frequency versus input to output gain also on page #8
(and its frequency restrictions, unless modified)
3: The harmonic output graph on page #9
(which displays a basic / average "delta" of 70dB.!!
Hell., even on page #10, it explains how to interpret the front-panel bar-graphs, which displays both PEP power and SWR., and both in "real-time".! :)
As my "profile-signature" states...
One of my biggest 'pet-peeves' in life., are those folks with an attitude that's basically saying...
"Hey look man, I've already got my mind made-up, so PLEASE don't confuse me with the facts".!
Regards / 73
Eric Klein
Klein Communications
Also as KY8E
PS: I do NOT sell them (RM amplifiers) or Sirio antennas (which I also spent half-a-day at their facilities the next day) or radios, or even microphones. Ever since 1980, when I started my Motorola-only, commercial 2-way radio communications, one-man-show business (over 200 customers and over 3,000 radios), it has always been about absorbing electronics knowledge, schematics, trouble-shooting, repairing, etc., and then doing my absolute best to explain / educate such things in "layman-terms", whether complex or mundane to others, with the goal of keeping other Folks from spending their hard-earned $$$ on "urban-legends" and / or "slick salesman" :-(
Eric, I took the time to investigate everything available on this topic before posting. Including going to the FCC website and see if any certification number had been issued for the BLA-703. I can't find anything listed anywhere for that model number. Can you provide it? On the other hand, I have no problem finding the FCC Certification Number for the BLA-600.
I wasn't changing the subject. I was simply pointing out that separate band input networks are not required on broadband solid state amplifiers. Also, that the necessary harmonic filters for the output section, cost under $150 to add, for all HF bands, plus 6 meters.
With respect to the RM-3, there are very few linear rated RF transistors in this package. The ones that are rated for this application, are highly advertised as such. In the absence of a semiconductor manufacturer's data sheet, it is very difficult to believe that this transistor could possibly be rated for linear RF service.
The only amplifiers that RM Italy manufactures with true linear rated RF devices, carry an FCC ID number and are very expensive. They use Freescale devices at higher voltages in order to meet difficult IMD specifications. They also brag about and publish the actual part number.
I have an extensive background in RF engineering and have worked for every company from Motorola to Microphase, before selling my own business and retiring 3 years ago. Sirio custom manufactured a line of antennas for my business, for 20 years.
I know it's easy to remove a harmonic with as little as two additional parts. I know it's impossible to achieve decent IMD specifications with inexpensive switch mode transistors, operating on 12 volts. That's why the real transistor number is not published and we see nothing related to an IMD specification on this amplifier.
Like you, I am interested in supplying the Layman with accurate information. In this case, it requires the specific FCC ID number for this amplifier, and if the manufacturer is claiming the "RM-3" is a real RF rated transistor designed for linear service, they absolutely need to publish the actual part number with a reliable manufacturer's data sheet.
I recognize I sometimes come off with a lousy attitude and apologize for that. In this case, I'm just looking for the meat and potatoes, to see if they line up with what's being advertised. It just appears to me that RM is advertising a little more than they are selling and they don't need to because they are selling plenty for this price.
The BLA keeps shutting down in SSB
Likely you are overdriving it in SSB. Or it is not getting sufficient volts/amps.
beeps that I'm out of the band when I am on ten meters
From page 1 of this thread, it seems it comes with 10 and 11 meters locked out.
Have you done the conversion to enable it to operate on 10 and 11?
Post number 11 on first page has two mods, one to open ten and 11 meters, and one that defeats (somewhat) the protection that detects excessive harmonic content in the signal and shuts down.
It's ironic that the RM engineers call this AM for American Mode because American operators (11 meters) have peaked and tweaked radios that trigger the protection.
The BLA keeps shutting down in SSB and beeps that I'm out of the band when I am on ten meters. I've used two different transmitters, the same result, shut down.
The BLA-703 "straight out of the box" is designed to operate within the entire 10-meter band, and only needs the 11-meter band modification (ie: R60 removed) for those who wish to operate it in the 11-meter band and / or the upper and lower 11-meter "free-bands".
If you are getting the "4-beep" shut-down warning, then (as the manual states all of the 6 protection-modes on page #9 of the included user-manual) your transceiver is allowing some amount (as small as it may be) of 2nd harmonics (above 30Mhz, or sub-harmonics below 25Mhz) to get into the amplifier's input detection circuitry.
If that's the case (ie: getting the 4-beep" warning) then follow the instructions contained in the 2nd half of the "11-meter conversion" article (web-link below).
It explains in detail., just what causes the 4-beep fault, and how to easily make the "firmware-change" from the amplifier's front panel (nick-named the "AM" mode) to help in minimizing the problem, which is helped by changing the amount of "consecutive-faults" (ie: to 25 detections) over a period of about 1.5 seconds.
If once the firmware change has been made., which is denoted by the AC power-up cycle beeping the Morse-code letters A and M (ie: dit-dah, dah-dah), and you're still having problems., then simply add some type of quality, inline, 30Mhz harmonic-filter box (between your transceiver and amp) to filter-out any possible "dirtiness" of your transceiver, as the BLA-703 is quite sensitive to such frequencies, and is why all the new versions RM produced (and American sold after November 1st of 2024) has the "user-ability" to make the firmware change if / when needed.
Regards / 73
Eric Klein
Also as KY8E
PS: If you can't get the AC power-up beep to change from the single / long beep, to the dit-dah, dah-dah Morse-code beep., then your BLA703 is from the earlier edition, which were being sold in Europe starting back in about February of 2024, and only the factory (or me) can "load" the ability to change it from one mode to the other...
No, not yet. There is a solder bridge jumper that I think needs to be removed. I will try that and see what happens. It's really annoying because the amp isn't being overdriven, and I tried two different exciters.
The problem I see is the manufacturer won't mention how many transistors are being used to reach this power level or, what type they are. The price indicates they must be the cheapest switch mode transistors that will work. Advertising the part number might complicate marketing the amplifier as being "True linear" or "rugged".
RM does make an FCC approved 500 watt "True Linear" with a real linear rated RF transistor. To build that, it cost $2,000 more than this amplifier, for good parts to be placed where they matter. When RM is not completely embarrassed about the transistors they use in their amplifiers, they specifically advertise the real part number.
Now that I've picked on this amplifier, I will point out some possible good things. It claims to have protection against overdrive and high reflected power. This could give unreliable transistors, a decent chance at having a reliable life. Its price, is this extremely low. If it proves to be at all reliable, it may fill a niche in the market.
I didn't see a Price, just curious how much they are asking????
Reactions: Radioman56
When you read the article above (if you've got access to that Facebook web-link) you'll read that the "R60-jumper" ONLY needs to be removed if / when you wish to use the amplifier for 11-meters.
When it's new / "out-of-the-box"., it will operate on the entire 10-meter band (only remove the R60 jumper for 11-meter operation).
If you're still getting the 4-beep "out-of-band" warning., and you're not over-driving it (which would cause the 1-beep "overdrive" warning)., did you in-fact., already perform the "AM-mode" firmware change-over operation (also explained in the above linked article).?
Once the above "AM-mode" firmware change has been made (as mentioned a few times now) every time you power-up the "AC-mains" rocker-switch., instead of hearing the "factory-stock" sounding "one looong beep"., you'll instead hear the Morse-code signal / beeping for the letters A and M (ie: dit-dah., dah-dah).
PLEASE let us know which of the two (2) differing, AC power-up, "beep" modes you're hearing.!
Regards / 73
Eric Klein
Also as KY8E
Reactions: Dusty1USA
The main importer of "all things RM"., is selling them for 800 plus shipping (he only charges what it actually costs him), and although they're coming out of the "lefty" state of California., there is NO sales-tax being charged to out-of-state buyers.! :)
Here's a web-link to the FB article concerning the above:
And here's a direct web-link to the sales page:
Hope that answered your curiosity.!
Regards / 73
Eric
Regards / 73
Eric
It does,thank you Radioman56!
Regards / 73
Eric
I’ve just purchased mine in the U.K. so it is the export version for £795. Not cheap but hopefully worth it. I’ll report back once received and fully operational. I will pair it with my Yaesu ftdx10.
Hi "Miura",
Just make sure that once you receive it, to check that is contains the new "user-changeable" Firmware update, that gives you the ability to change between the factory / stock single "power-up beep", to the Morse-code letters A and M, as explained in my "conversion" article.
If ya didn't read it (or can't find it), I can repeat / rewrite the simple, front-panel, procedure to switch between the two (2) modes, concerning the 4-beep, out-of-band sensitivity.
If it does NOT have that ability (to change the 4-beep, out-of-band warning sensitivity), it means that it came from a "dealer's" new-old-stock which was RM's first version, and was 1st released in Europe back around February / March, 2024 time-period, and should be returned to acquire the "new-version".!
If you don't already have it (and for your convenience)., I've attached a PDF file copy of the owner / user manual., but it of course does NOT contain any info on the two (2) different modifications which can be applied (ie: for 11-meter operation, and the out-of-band warning sensitivity).
Regards / 73
Eric Klein
Also as KY8E
RM Italy Linear Amplifier Help and Information
Many thanks Eric for the many useful advices. Keep in mind I live in the U.K. so it might be different here…
Is there anyway to check « new-old » stock with the serial numbers?
Cheers & Beers
Giles
Many thanks Eric for the many useful advices. Don’t forget I live in the U.K. so it might be different here…
Cheers & Beers
Gile
Howdy Gile, unfortunately, the short answer is no :-(
This is because the "1st-run" of them (ie: low serial-numbers) were only sold in Europe (no direct sales in America until Nov. 1, 2024) and of course being European sold, were "Export" units (ie: 11-meter band "open").
BUT., some of those "1st-run units" had a problem with damage occurring during the final shipping "leg" from the distributor to end-user (ie: caused by typical "throwing about" in transit) in which the amplifier's internal VERY heavy (9#) heat-sink, partially breaking-away from the rear of the steel outer cabinet :(
So., most of those units were shipped back to RM to have the heat-sink mounting system to be GREATLY improved :) and then shipped back to the distributor(s).
And while back at the factory, most all of those units, also had the new Firmware "flashed" into the front-panel CPU board.
Bottom line.??
You'll only know for sure, when you attempt the front-panel accessible, change-over (and back) as described in my article.
Regards,
Eric
PS: Here's the web-link to that article:
If you don't have access FB, let me know, and I'll just copy & paste the section of that article which explains the simple process in excruciating detail ;)
Eric, thank you so very much for your answer!! Very much appreciated. Also having no FB account, I would love for you to paste your infos here as I had a very hard time reading your posts. Sorry for the hassle. Despite my problems opening your pictures I read all your threads and was very impressed by your extensive knowledge and expertise.
Happy New Year :)
Giles
  • @ Spanish:
    Where do i upload schematics
