I am planning to build a ground plane base for a 102 whip to put on top of my camper. I was thinking maybe a 36" circle of plate with 8 36" wires every 45 degees? Should be plenty?
Yes, I would like an a99 and would love a moonraker 80 foot up, but I have enough problems with the owner here and would like to stay with the whip.
So can you have a TV antenna, and if so, how high can the top of the mast be above the roof?
Or you could mount the 102" on the top edge of the roof and drop a 108" 20 gauge wire basically straight down toward the ground from the mounting bracket/ coax shield.
That should make a decent center-fed vertical 1/2 wave dipole with ~3dB gain more than a 1/4 wave ground plane, roughly equal to an A99, and with maybe a 1.4:1 swr.
