i got 3 scanners going off their own supply,2 -2 meter radios hooked to mjf 30 amp switching power supply a mirage 2 meter 200 watt amp,and stryker 955 hp and a opticom [texas star ] hooked to same amp.
i only run 1 rado and amp at a time . just started acting up yesterday but key mic (silver eagle ) up on ssb all is well but i key up on am and as i speak im getting a buzzy sond coming from the power supply. i unhooked everything but stryker and turned it on keyed up same buzz.oddly no other radio does this. i took mic apart no wires out of place in plug or board.
put original stryker mic on same buzz. i talked a short bit last nite nobody noticed any odd sound from my signal amp on or off on am and ssb.
swr by big meter shows almost flat 1:1 across band.and radio meter agrees. no matter where i set mic gain i got this buzz on am.
is power supply bad or what? ive had this supply 3 years n its always worked just fine for me.
