Cobra UK 29 LTD ST Mod
I looked at the alignment and it does not show L308 for align. parts layout shows it to be a coil spring. so you would leave it alone.
If you look at the schematic, L308 is the 4th coil going back from the antenna jack toward the final. The arrow above L308 indicated that it's a tuneable inductor, not a can. - 399.
Reactions: tecnicoloco
here is a service manual I found for the UK 29 radio. it shows the layout of the parts and is hard to read. maybe you can blow it up enough to read the parts. I looked at the alignment and it does not show L308 for align. parts layout shows it to be a coil spring. so you would leave it alone.
https://downloads.cobra.com/CB/Models/29-SERIES/UK_29_LTD_ST/UK29LTDST_service_manual.pdf
Many thanks Sonoma
Just what I wanted and it will come in handy I shall print it out as soon as I have new ink .
Kindest Regards John
just did the "wideband" mod on my UK 25 LTD ST - now the UK/EU knob becomes FM/AM, BRT/DIM/MID switch is UK40/LOW-MED/HIGH bands, tone 1-4 becomes banks 1-4. e.g, UK/BRT/Tone 1 gives the full UK CB27/81 FM channels
So, I believe my radio has this mod but it's never been explained to me on how to use it.. I'm guessing that CB fm would be with the tone set to 1..? Can anyone confirm the tone settings?!
I think my cobra UK 29 ltd st has a similar mod.. Can you explain the function again pls... Especially how to find UK cb ch19..?!
Benny if you click on G12ALE's user name this is what you see below. He has not been on the forum since 2022 after one post.
G12ALE
New Member · 57
Joined Sep 23, 2022
Last seen Sep 23, 2022
G12ALE
New Member · 57
Joined Sep 23, 2022
Thanks.. Just reaching out to anyone who might be able to help... Currently sat on top of a hill playing with the radio.. All I get is some fella speaking Spanish!
