Yaesu FTX-1 MARS Modification
Happy_Hamer
Administrator
Staff member
Mar 22, 2001
5,063
216
123
MARS mod on a Yaesu FTX-1 radio.
Proceed at your own risk.
Disconnect all power.
Remove the three black screws on the bottom speaker cover and remove the cover.
Remove the three silver screws hidden under the speaker cover.
Remove the three top black screws on the back to detach the front unit.
Separate the front unit and RF unit.
Solder jumper 1 to short it.
Reassemble.
Perform a factory reset.
That
Reassemble.
That does not work. I tried on 2 FTX-1 Field unit heads and there was no change. Tested jumper 1 with a meter and they are definitely jumped. What am i missing?
That
Reassemble.
I know this is an old post but I just seen that GMRS can be enabled by replacing a chip when doing the MARS Mod. This was said to be available by Gigaparts and won’t void the warranty? Anyone know the chip?
