Radio shops
Skip seeker
28
Ireland
I’m basically Looking information on modifying an export radio to be able to broadcast on
11 meters , I’m considering buying a stryker SR 955 + from a shop a mobile trailer radio shop in Houston Texas after a check on
There website and saw photos of there work bench I couldn’t see an Analyzer or scope , seems kind of odd to me these pieces of equipment are obviously needed for the the tune and conversion .
Reactions: tunercars
As far as the 955hpc, you're better off buying one bone stock and doing the simple 11 meter mod yourself. Those radios are in great shape just converted. It's not a ranger made so these leave the factory aligned pretty well.
I just thought it strange that the work bench looked preety Bare with regards to test equipment, I wasn’t aware they left the factory more than less plug and play you see a lot of radio shops charge $45 upwards to convert to 11 meters
Unfortunately a lot of truck stop cb shops aren't going to use the right test equipment and you probably wouldn't want them in there screwing with the firmware adjustments anyway.
And yes, the qixiang made Stryker and other cousins leave the factory in really good shape. They may have an occasional stray that leaves a little off but it isn't often. I think you'll find that many others here will tell you the same.
Get a new untouched one, do the simple mod and give it a shot. Save your 40+ bucks. Or buy one from a reputable shop that does an actual alignment if needed but won't sell you the golden screwdriver peak.
I could just buy a stock radio there is a Filipino Ham operator based in Houston that’s knowledgeable and would have the proper test Equipment needed for an Allignment
Paying 4 and 1/2 Bills for a radio you just wouldn’t want any of these truckstop techs messing inside
I recommend Radioddity radios. They are made in the same factory as Stryker. But, have support and a warranty. Also like half the cost of a Stryker. Look at QT-60 Pro and QT-80. Easy to enable 11m and NO alignment needed! If you buy it from the Radioddity website, I arranged a discount for WWDX members. Enter WWDX at checkout, for a 15% discount (radio only, no bundles). Also check out Amazon, as Radioddity had some deals there that are not on their website.
SL
Here is a quick video on how to convert this radio. It will take longer to remove the cover then do the conversion.
SL
Appreciate the lift on radioddity I haven’t looked into that Brand are they similar to the CRT brand of radios.
Holy smokies that’s a very simple requirement I’m taking it once you cut the white wire you should separate the ends so they can’t touch.
SL
Looks identical to the Anytone AT 6666
Qixiang, a Chinese company, make Anytone, Radioddity, and the newer Stryker and CRT radios.
Anytone is Qixiang's "house" brand, and their most common radios are the original 6666, The 6666Pro, and a slew of versions of the 5555, the newest of which is the "short case" 5555N2. They are all Qixiang radios inside with different companies "badges" and model numbers on the outside (Stryker, CRT, Radioddity etc.)
The only differences are the different appearance of the Styrker version, and whether or not you get a warranty. The Stryker version also has more of its functions bought out to the front panel with knobs/switches, whereas the others have those same functions in the main menu.
There are BIG price differences between the brands with Anytone generally being the cheapest (but with no warranty or customer support).
Edit to add: These are all SDR based radios, so there are NO internal adjustments in the traditional sense. So if someone tells you these radios need to be "peaked and tweaked" they are full of bovine excrement.
I did a review on the QT-60 Pro. Check it out, it is an awesome radio. I use the 60 Pro portable and home (nice big display) and the QT-80 in my car. These radios are the best in class today.
I still prefer the old style look
Of the Stryker with the chrome Bezel compared to the dull looking anytone , but I do like the compact design of the 6666 a lot of radio operators Enjoy using them and the compact design would be a good choice for a mobile radio.
  • @ 357:
    holy man no activity or what?
    357 has left the room.
