So much for resale value (TRS Challenger 1400).
TM86
Jul 6, 2014
2,357
3,883
273
Payson, AZ
Grabbed this from the Bay of Fleas a while back.
If you look closely you may notice a dark streak down the face of the radio about where the squelch knob is. Turns out somebody had let something nasty drip on and run down from the top to the bottom. So I just had to clean it.
Yep, took the black right off. Only where the mystery goo was, but still. In addition to the squelch knob it also crossed the "Low" filter button. Which means it probably got inside as well.
Which it did.
It's not too bad, but I still have to more less remove the front of the radio to get rid of the rust, then paint what remains to prevent a repeat performance. There's also rust on the inside front of the bottom cover.
But no matter what I do, this thing will never have the value it could have had some previous owner not allowed the face to get eaten.
Which I guess means I'm free to get stupid with it since a simple restore is probably not in the cards anymore.
Sadly many radios probably fall in this category. Never know what is inside. (Better than a roach infested radio, but the roaches died 15+ years ago.) All you can do is just clean it up the best you can. Better than letting it rot away another 10+ years.
Yep. And I already dealt with a roach infested radio. Then there was the one that had been in a heavy smoker's home. Took leaving it in the garage for a month and several applications of Febreeze before I could even clean that one.
Anyways, progress of a sort.
Just hope I can bend the little metal tabs that hold the meters and clock back without breaking them when it comes time for reassembly.
Little bit of progress.
Wire brush removed most of the crud and rust. I'll hit it with some rust converter this weekend. Then I I'll have to pick a color to put on top of that.
I'd like to get the top and bottom covers stripped and done over with some hammer tone black, but I need to find someone with a booth for media blasting.
It lives!
Not sure why the clock is missing some segments. I'm hoping it's just some bad connections I can fix. If not, well, that's when things get interesting.
All three mode indicators work. RECEIVE light works. Meter lights work. No TX as far as I can tell, but I can hear the relay clicking. RX appears to be fine as far as being on frequency goes. No segments missing on the channel display. Even the little buttons to set the clock work.
Really, it's better than I was expecting.
PLL is a uPD2810 so no crazy frequency mods unless I want to go with a DDSVFO and maybe rewire the clarifier control to act as a RIT knob for that. Which I really don't right now. Maybe, if I manage to blow up the PLL during the planned recap.
Recap done, it appears to have been successful. Found both dry and liquid crud under some of the caps. All cleaned up now, of course. Managed not to blow up the PLL, somehow.
Figured out the transmit problem, too. Some utter dumbass, who just happens to have the same name and face as me, wired the mic plug 180 degrees out when reassembling the front panel. That's been fixed. Plenty of swing on AM and sideband. I'm saving looking at it on a 'scope for the alignment.
Still have to get as much glue as humanly possible off the tuning cans. The four on the PLL/mic amp board are done. Leaves me just 13 more to go.
Still haven't figured out the missing segments in the clock display. Not looking forward to doing it, either. I've already reflowed a bunch dull gray looking connections on that board to no effect. I'll have to look up the clock chip and see if it's got bad outputs and/or ohm out the wires in the ribbon cable.
But overall, she's coming along nicely considering what she's been through.
Thought I had it done. Bang on frequency, output looked good on a scope. So I buttoned her up. Suddenly no receive audio past the headphone jack and doesn't work on 37 and above.
So apparently there's a few remaining issues. :rolleyes:
  • Wow
Receive audio issue fixed. Broken wire to the tip terminal on the phone plug. They didn't design in a service loop, so I had to extend the wire a bit to connect it back up. Works with speakers or headphones. Must have been hanging on by a single strand and the bumps when putting it back together was enough to break that.
Higher channels working. Turns out I had tweaked the VCO coil a little too far to one side and hadn't rechecked it afterwards. Now have all 40 channels.
Haven't decided what to do about the bad segments in the clock just yet. The AMI S1998A chips are still available through the obsolete chip dealers so I can get one if needed. Just not sure it's worth it considering how bad the clock board looks and the fact the face is pretty disfigured.
Also, one of the speaker terminals is sort of hanging loose. So if anyone knows where I can get a 3 1/2 inch, 1 Watt, 8 Ohm round Sanyo DG70B or two that would helpful. It works, I just don't like that terminal hanging in free space.
A face only a mother could love
img_3223-jpeg.75311
Right, needs some glamor shots.
-50 dB in on channel 1.
No signal on channel 40.
-50 dB in on channel 40.
Transmit on Channel 40, just to see the "ON THE AIR" panel lit up.
So, not quite as bad as with all the knobs off.
Nice work on the Challenger!! I too have sanded and re-sprayed a few cases that had some rust/stains on them. I had a question about the clock. I'm not sure of the best way to troubleshoot one. I have a Teaberry Stalker XX and the clock only flashes all 8's. The clock board has a TM4801P chip. Any tips?
Thanks!!
