Non SDR Radio...
So I've had my Yaesu FTDX-101MP for a couple of years. But I still revert to my barebones Elecraft K3. I didn't notice this i watched DX Commander's video about "Why i dont want an SDR radio".
So what nonSDR radios are still available?
Can one still get a Hilberling?
I asked Google's AI if the Kenwood TS-890 is an SDR radio.
No, the Kenwood TS-890S is not an SDR (Software Defined Radio) in the modern "direct sampling" sense. Instead, it uses a high-performance superheterodyne architecture.
Key technical distinctions of the TS-890S include:
  • Down-conversion Receiver: It uses a full down-conversion method with a first Intermediate Frequency (IF) of 8.248 MHz.
  • H-Mode Mixer: It features an H-mode mixer design with four fast digital switches for high signal-handling capability.
  • Hardware Filtering: It relies on narrowband crystal "roofing filters" (as narrow as 270Hz) to eliminate nearby interference before digital processing occurs.
  • DSP Utilization: While it is not a direct-sampling SDR, it uses advanced Digital Signal Processing (DSP) for functions like IF filtering, noise reduction, and signal decoding.
  • SDR Integration: While the radio itself is a legacy-style receiver, it can be connected to an external SDR for use as a panadapter or via third-party SDR client software.
The TS-890 is a variant of the TS-990 but with only a single receiver.
I have spent many hours using the Flex 6600 and 6400 in CW contests. I still prefer my K3 and crystal filters.
Kenwood TS-590SG is still available new, and so is the Icom IC-718. Neither one is SDR.
On edit: I forgot to mention that the Kenwood is great for people that are blind. It has an add on VSG-1 (voice guide system) module that announces many of the key presses, frequency, S meter reading, etc. I found this out thanks to a female ham op in my local club.
73,
Brett
Looks like im just going to continue on using my FTDX-101 and Elecraft K3.
Now if i could find a reasonable legal limit Amplifier.
I prefer the older analog stuff. Cubic Astros, KW TS-530/830/930S/940S, JRC of various stripes, Yaesu 102, 90x and 980, Ten Tecs ranging from the Corsair II through the Paragon II. The ONLY drawback with some of these is Inrad exiting the filter market for the most part. If you want to go back to the non-computer-controlled era, Drake 5 and 7 line stuff. I just threw a set of Noble Radio 2.8KHz filters in the primary slots of one of my TR-5s and TR-7s. Plan to repeat that purchase in a month or so.
