Galaxy dx99V2 off 4K on various channels
Replaced both adder chips today. No change. Assuming these chips are correct - and based on the pin-outs, it appears it should do the job, it must be something else.
Voltages of both adders and pll will help. There are resistor arrays that can give bad logic on the pins. Maybe even a capacitor array, but idk if your radio has them. I will need to check the schematic when I get home.
Input voltage or voltages of every pin? If all pins, does it matter which channel I’m on?
Yes, voltages of all pins and on a determined channel. Channel 1 if you like.
For ch1 band e, the pll program pins should be...
9 high
10 low
11 low
12 low
13 low
14 high
15 high
16 high
17 high
High=>5v, low=<2v
That gives the binary sum of 271..
Edited to correct.
If IC7(IC5) pins match
2 lo
4 hi
6 hi
15 hi
And IC6(IC4) match
2 hi
4 lo
6 lo
15 lo
Then the diode matrix and subsequent band switch is ok. Maybe a bad channel switch.
Sorry if this seems confusing.
2 lo
4 hi
6 hi
15 hi
And IC6(IC4) match
2 hi
4 lo
6 lo
15 lo
Yes, it is a bit confusing for me. And I didn’t see this until after I got the voltages on channel 20 (which incorrectly reads 27.445). I’m going to post this. I hope the columns match up so it’s legible.
[edit ic labels—now correct]
IC4————-IC5
1- 0—————-0
2- 7.7—————-0
3- 7.2—————-8.2
4- 0—————-7.7
5- 8.2—————-8.2
6- 0—————-7.7
7- 8.2—————-8.2
8- 0—————-0
9- 0—————-0
10- 8.2—————-0
11- 8.2—————-8.2
12- 0—————-0
13- 8.2—————-0
14- 0—————-8.2
15- 0—————-7.7
16-8.2—————-8.2
Should I provide other details?
Yes please
9 high
10 low
11 low
12 low
13 low
14 high
15 high
16 high
17 high
High=>5v, low=<2v
Edited to correct.
You replaced the adders, and did a very good job soldering them in btw. Need to know what the pll pins read while on channel 1, band E.
I think your radios has the rci8719 pll, not the mc145106, and circled in green above is a capacitor array. Remove it and see if it goes back on frequency. If so, you can replace it with individual ceramic capacitors. I have seen this once. Circled in blue is resistor arrays I mentioned earlier.
As Brandon pointed out, you have a pin that isn't going high when it should, P2. So, if the capacitor array has a faulty, shorted cap on that pin, when the adder sets that pin high, the CA keeps it low through its short. That array is just a bunch of capacitors sharing a common ground. It should function for awhile without it but it may get erratic, so either replace it with another array after verifying it's faulty, or wire a few ceramics together. I think I have a pic somewhere of what that looks like.
Reactions: brandon7861
I think your radios has the rci8719 pll, not the mc145106.
So, I should switch to Band E channel 1, not 20, and check those voltages and learn them here.
Before getting those, I should remove the capacitor array to see if that resolves the issue.
Sound right?
Yes, that's most helpful.
Sound right?
Yes, remove it first and then check, if the radio is still off frequency, put it back in.
I can see 145106 on that PLL it's not an 8719.
  • @ 357:
    holy man no activity or what?
    357 has left the room.
