Uniden Madison (mb8719) PC-411AD schematic
Cable Guy
Growth must be chosen again and again.
Dec 29, 2010
1,363
1,458
173
413-West Tennessee
Looking for the schematic, this board is similar to a cobra 2k but has many differences. It is also related to the stalker xx. I found something of a service manual but it is difficult to read the schematic. Does anyone have what I need and willing to share? Thanks.
inquiring minds here want to know what your malfunction
is with that Madison radio?
I have worked on several of these Uniden boards now,
and am taking a liking to them.
I had a Madison a few weeks ago, with the carrier osc
xtal X4 falling out off the board due to the corrosive glue.
Well, I have been recapping, removing various mods and replacing clipped components. Everything is back to stock except the am modulation adjustment. It is limiting now due to replacing the transistor and diode, but there is no control via vr12. The modulation limit circuit is different, and I'm trying to find a schematic that represents what's going on so I can fix it. I haven't had much time to look into it this week.
Hey Cable Guy,
So, I have a Stalker XX and it has the 8734 chip in it. The Sams manual for it shows the 8734 as well. I think that the export version of the Stalker XX may have come with the 8719 and that may be the schematic that you have. The Madison V2 is shown in the Sams 230. It shows the 8719 chip so that may be what you are looking for. See attached.
Reactions: Cable Guy
yes, I see now. no AMC adjust VR12 on the Madison. yes VR12 on the 2000.
I usually turn them off. ALC and AMC. I don't like how they
hang in briefly, after they kick in. certain capacitors can be removed
to prevent that. but I adjust the mic gain properly and talk.
but when the radio is going to somebody else! look out!
power mic's are hooked up and all turned up
to the max.
There is a vr12 on this Madison. I will get a pic soon. I already change the amc timing cap/action but I do want control.
Yikes, I'm always looking out for and cleaning the glue. This one also had a missing varactor diode and the clarifier did very little, I went looking for a reason and couldn't find the diode, but eventually found where it's supposed to go and replaced it. I'm removing the clock and installing a frequency counter per request and have to cut some smoked polycarbonate sheet for a replacement on the face, I don't like the empty clock holes, so that's next.
Hey Cable Guy, I have the version of board CB 230 shone above, board #PC-411 AD with the MB 8719 chip Where are you hooking the frequency counter to this board. Thanks John
John, I didn't get a pic of the tap point and I don't really remember, but I think I pulled from TP1.
