Tested a portable elevated "V" today
nikdfish
31
69
28
72
I got around to testing a printed "V" antenna base design today. The base was done with M10x1.5 threaded inserts, but I have adapters to permit use of whips with a 3/8-24 thread. This was an initial test print with modification. The current model is more refined.
I mounted the base on a fiberglass push-up pole with a ACME 3/4-5 threaded end, supported by a printed clamp on tripod. I used a couple of 102" telescopic whips, fully extended for the first test.
With the whips fully extended, it covers 11m @ < 1.5.
With the last segment of the whip shortened to 10", it covers 10m @ < 2.
At some point I will be testing with a 220" whip in the vertical position & the two 102" whips in a downward (45 degree) angle as radials. I think 12, 15 & 20m should be usable without a transformer or coil. A small loading coil should enable 40m (& maybe 80m?).
a few years ago, on 17 meters, there was a guy that
vacationed down in Jamaica and he had an antenna
set up like that, right on the beach several feet
off the sand. I would talk to him during his
Winter vacation down there.
And also there was a guy that would
go to a park near Phoenix AZ and had the same set up.
He had a good signal here.
(He was not POTA, just his weekend thing at the park)
2 quarter wave radiators in a mild upward
going V antenna on 17 meters. 100 watts.
there is a Ham in northern CA selling that set up.
I see on your set up, you can have a vertical with
2 downward pointing radials.
make a 17 meter version.
but if you use it for POTA on 17 meters,
the "NAZI Hams" will get mad and say POTA is
not allowed on 17 meters. also "Sad HAMS" and
"Grumpy HAMS" may get annoyed also.
when I repair these export "CB" radios and amplifiers
that can go to 29.6 MHz FM and I use them there,
tell them what I am using, the "NAZI Hams" get mad.
When testing on 29 MHz AM and I say I am using a
"Ranger" they assume I am using an old Johnson Viking
Ranger tube transmitter. So I correct them and tell
them about RCI radios. oh, and when I mention a
PALOMAR amplifier, yikes!
I have all this stuff correctly biased and modulated.
sounding good on my Motorola Service Monitor.
hopefully someone will get a giggle out of this. :LOL::LOL::LOL::LOL::LOL::LOL:
Did you sweep those bands??
I didn't use the 220" whips that day, but did a quick look this morning.
First was an overview of the 220" whips as a "V", fully extended.
This is a broad scan
Now a closer look at the 20m neighborhood
So a little shortening should do good with 20m
I also took a look at using one 220" whip as vertical & two 102" whips as radials.
The center is a bit higher. I shortened the vertical by one section (at bottom) and re-ran it. I don't have a wide scan pic, just one around 17m
That's all I've gotten to so far. Eventually I will map out a chart of whip length/configuration against bands. It may take a bit as working with the 18' whips is a bit of a pain.
I think I have talked to that guy in Jamaica several times. Those POTA folks come up with some great ideas that are easy to setup like nikdfish has done here with his antenna. I always work a POTA when I hear them calling and no one is coming back to them, I think its a great program, no different then WAS or similar programs. Anything that gets folks out on the air is great in my book and these type of EASY UP antennas help a lot.
I also second the Hams getting upset with those export rigs. I fix local CB and Ham radio and amps. Most CB stuff is taking out the splatter Modulation mods and such, if I cannot repair the splatter mods I dont work on it and they get mad sometimes.
Reactions: Crawdad
My version since I don't have a really kewl printer for stuff like this.
Two 102" steel whips, a 3" pvc connector, two 1" stud mounts, two 3" 12 ga. wires for connectors to a 1:1 balun rated for 500 watts to keep RF off the feed line.
Don't have a Rig Expert but using a Sark100 analyzer I have a 1.1 swr at 50 ohms for the center of 11 meters.
Have it hanging in an Oak tree in the yard at 36'. Hard to tell the difference between it and a Sirio 2016 mounted at 42' to the base of it above the house except for the nulls off each end of it.
Working on another component for the pushup.
This was a test print/build to see what needed tweaking on the design, but should be usable. Printed in ASA. Coil is done with 16awg tinned copper. Sliding contact is a keystone 5231 battery contact. M10 inserts on both ends, a M10 grub screw was threaded in at the bottom. M4 inserts for the screws & slider bridge screws.
The inductance calculator says it should be ballpark 70 microhenries. 66 turns of a 1.4mm conductor on a 50mm form over 135mm span. I haven't yet done any sweeps with a vertical whip. Some minor ripples in the wire because it was recycled from an earlier test build.
Reactions: 2RT307 and Crawdad
THAT is cool! I picked up an Opek 25' telescopic whip from MTC a while back, and would like to add a coil to hit 40 meters. Your coil looks very good!
73,
Brett
The coil may be overkill for most uses. The closely spaced wraps make adjustment a bit "twitchy". I may do a variation with about half the potential inductance. The additional space between wraps should make selection a bit easier. A smaller diameter would also make the steps smaller.
Full coil depth with a 102" whip vertical, no ground/radials, pole not extended puts 80m in reach.
With the 220" whip vertical, no ground/radials, pole not extended. This much coil for 40m
With the 220" whip vertical, pole not extended, I am making contact with the ground side at the analyzer.
Only needed this much coil to hit 80m
73,
Brett
Chuck: KK6USY/Firerunner did a coil for 40m...
Dug up the LCR meter & replaced the battery so I could check the numbers on the slider coil & see how they compared to the design intent.
Min - 0.7 microhenries
Max - 66 microhenries
Somewhere in the middle - 26 microhenries
Also did a shorty that should move the 220" from being adjusted for 20m down to 40m, at least based on the calculator results calling for 6.2 microhenries. Still need to test that.
Reactions: 2RT307
