Pearce Simpson Bengal SSB Low AM Sensitivity
The plot thickens...
I hooked up my VFO and tuned in to Chan 38 and had my wife give me some 10 counts on the Midland. I tweaked in the "crystal" freq until her voice was just right and started listening to 38/LSB on the Bengal and had the Midland in the other end of the shop.
Although the background noise is high (normal?) on sideband the actual signals behaved the same way they on AM! I am starting to wonder if the FET2 3SK22-Y is tired... The voltages look good but it might be starting to break down. I have did a little searching but don't find any of these for sale on this side of the pond.
Anybody know of a good substitute?
73,
I removed the 3SK22 and the background noise didn't change. I found a source for the them and ordered a few so they should be here in a couple of weeks...
OK, I'm about at the end of my rope on this one. I got in the new 3SK22 FETs today and popped one in - no change! I believe this radio has had this problem for quite a while and somebody has did extensive troubleshooting. When I went through the IF train I saw signs that several IF cans had been removed, probably for testing, and other traces.
So, it remains mostly deaf only receiving very strong signals and when I key up my walkie I only get about an S3 indication instead of over S9.
I guess this will go on the "maybe someday" shelf. Maybe if I live long enough I'll get back to it someday...
Thanks for the help!
73,
Reactions: doffo
It was worth a shot. I got an older President Washington 858 chassis radio which took away several hours trying to troubleshoot. I purposely put it up high on a shelf in the garage where I need a ladder to get to it. :D Keeps it out of reach so I do something else instead of trying to find out the problem it had. I did bring back down a Courier Gladiator PLL 23 channel thats been converted into a 40 channel. I think after all this time it had a bad Audio chip? I need to wire up a mic and then I can begin my luck to trying to repair it.
I did buy one a couple years ago for around $80 on eBay, an actual 40 channel one. Felt like it was a great deal. :)
It's been very hard to work on this with a copy of a Sams as the pictures are not very easy to determine where the components are actually at. I may need to break down and see what manualman.com has for this...
There is a normal schematic on CBTricks and a block diagram in the owner's manual.
edit re-read first post, I see you have the block diagram already.
Is it possible that the 1.5v zener at the source of FET2 is bad? If that shorted, the bias point of the amp would change.
I would also check D12. The capacitor isolating the antenna from the tuned transformer is a hefty 20nF (under 1ohm at 27MHz) and maybe a strong signal wiped it out.
  • Wow
Reactions: Ghetto and doffo
OK, I spoke too soon. After changing out FET2 it was totally deaf so I tried another 3SK22 and it was still totally deaf. I put the original 3SK22 back in and I was again able to "hear" strong signals. I'm suspecting the FETs I ordered were likely counterfeit parts. :-(
This makes me think the FET is probably OK so I will check out your suggestions, Brandon. The voltage reading at FET2, source, looks about right so I'm thinking the zener is OK. I don't see a 20nf cap on the schematic buit I'll check everything before the FET2 and antenna. If everything checks out I'm tempted to remove FET2 and insert a broadband high gain amp module between C32 and the base of TR5 and see what happens...
73,
Reactions: doffo
73,
I have no idea what the 3sk22 curve looks like, and I have a feeling FET2 is fine, but if you are set on trying something else there, you could use a 3-leaded jfet and adjust the bias to suit the new part. No need to go trying modules yet.
The 4th leg on the 3sk22, "gate 2", is just a connection to the case and often has bias potential applied to it to help reduce noise.
