Carlbuilt 400HD vs C400 vs CM400
That bias is just resistor providing bias voltage or temperature compensated bias circuit as it should be done? :cool:
Mike
The only builder I have ever saw do this was Peakaboo in the Joker amplifiers. He came up with and designed his own regulated AB bias scheme. He would even grind off component part numbers and values so no one would try to copy it. Best amp I ever owned.
He is selling those boards now. I bought four of them due to no time to make the boards from scratch myself. Each board serves 2 transistors. He uses the TIP31 setup. I dont know of any fulltime builders using that bias setup yet, the ones that do bias is just the diode/cap/resistor deal as far as I know. I guess thats better then no bias. I think Shockwave turned me to Him if I am not mistaken. Rob S also built like that too.
Ahem
I did it as well. I even had a thread here showing the schematic and everything but it's lost to time. I basically copied a Kenwood bias schematic.
Actually Carl does build biased amps, you just have to check the box for it at the time of purchase.
And I do agree
You should run bias for SSB if you want to keep it clean..
With those radios I don't think you need a driver transistor, but I never liked amps with built in drivers anyway
The bias he uses is class B schottky diodes and resistors. Garbage amps.
It's a CB amp, and in that sense they're all garbage amps, however it's still better than some of the class C stuff that seems built to include the least amount of parts and still make RF.
Cb amps are not Henry or Metron built quality.....
