Galaxy DX 98 VHP
Zman
K9FON
Nov 26, 2009
984
113
How can i make the amp switchable so i can turn it on and off and just run the radio output?
I need to know what wires control the amp?
Howabout the +13.8v amp feed wire?
Dunno if I would hook it up to the ANL switch tho; there is a LOT of current going through that switch if used to switch the amp's power on/off. Besides, the ANL switch is a hack way of doing it. Think I would keep the ANL switch - and all front panel switches - intact. Would use another switch and mount it on the radio's back panel. A switch that will handle 20A @ ~14v.
