Uniden Tempo 2020 / 8010 VFO
kopcicle
Sr. Member
Feb 17, 2016
2,237
3,715
273
Anyone care to explain what the %)*&^(^%& Tempo/Uniden is trying to explain in the 8010 manual when they describe the frequencies of the crystals to be used in the remote VFO ?
The crystal oscillator of the 8010 accepts 10 crystals for channel A to J . Like the 2020, the crystal frequencies must fall within the VFO frequency range between 9.138 kHz and 9038 kHz. The crystal frequency (fx) for any desired operating frequency is calculated by the following formula
fx = 9.138 - fF (Khz) where fF is any desired operating within 100 kHz coverage regardless of operating bands...
For some reason I am drawing a complete blank .
Crystals?
As in "fixed frequency" crystals?
That's the only reason for a crystal in the range of the VFO frequency, to take the place of the VFO for fixed-frequency operation.
To use a fixed-channel crystal in this radio, you still must select the correct one of five 100 kHz band segments and push that button to make that crystal work properly.
Considering the price of custom-cut crystals, why would anyone care?
Crystals?
The possible use of an ltc-1799 oscillator instead of crystals
Worst case 40ppm does seem a bit outside the pale.
I have used them before and it really depends on the temperature stability of the resistors oddly enough .
The oscillator is fairly stable but the multi turn trimmers are temperature sensitive. I've found better stability by replacing the variables with fixed resistors .
Sounds like a job for a 15-buck ChinaBay DDS board.
The spurious 'birdie' problem would be reduced by the low frequency it would be delivering. That, and the VFO oscillator in that radio doesn't actually mix with transmit or receiver signals. It feeds into the PLL that tunes the radio, and this would remove any 'dirty' stuff from a DDS chip from the radio's actual signal path.
Looks as if the N3ZI DDS kit would be a workable solution, maybe?
http://www.pongrance.com/
Used one on my Kenwood TS530, was stable as a rock. And the 530's PLL setup scrubbed any unwanted stuff from the DDS chip's output. Just had to put a buffer amplifier between Doug's DDS and the radio's external VFO input. His newer board has a buffer amp on it, IIRC.
I've thought about the DDS before when I was doing this
http://www.worldwidedx.com/threads/...equenting-frequency-mixes-and-a-panda.212836/
That got shelved for numerous reasons (life and work invaded) . I have several of the evilpay sourced LTC-1799 mounted on mini-boards . I'll get to further testing this winter. BTW I have the math but not the tuning/inductor for all the Ham bands now. It just took building a spread sheet.I also have the best estimates for the pre/driver/final tuning .
For now it's get the antique working then see what fixed crystals I have and compare them to the LTC-1799 .I suspect that without the buffer amp that used to be the doubler or trippler in the radios that the very square wave will be an issue. Can you say "harmonics" ?
We'll see ...
Thank You for the words
Reactions: AudioShockwav
https://www.qrpkits.com/freqcounter.html since the N3ZI kit is no longer available
Run over yonder - to the Boat Anchors section of another forum - and look up KW4H. He has a solution to your dilemma and used it to restore the Heathkit CW Twins, amongst a few others.
I threw out the idea of using such as a fixed-frequency signal source in rigs such as the FR-101, TS-820S/R-820 and others. Needs their Fix Ch boards yanked and the wiring slightly modded but the approach is totally feasible.
