The old hy-gain super penetrator antenna....
ORD
QTY SHPD
QTY Product ID Description Unit Price Line Total
1 1 170774 MATCHING STUB, SPT-500 $6.08 $6.08
1 1 170775 SHORTING STUB, SPT-500 $2.56 $2.56
2 2 463642 1 8 TO 1 1 4 ROD SUPPORT, BK, $0.14 $0.28
1 1 863427 BASE ASSY, W PIN SHORT,AV12, $6.90 $6.90
1 1 463056 MKII UPPER INSULATOR, 71, $3.12 $3.12
Subtotal:
Tax:
Shipping & Handling:
Total:
$18.94
$0.00
$12.00
$30.94
MFJ can hook you up!!!!
Hi can you tell me where I can buy the matching rod an the beta rod mines was stiles by a lightning and they dissapeared
Check out the newer version! Seems to be a winner!
I rebuilt mine and upgraded the internal wire so as to handle greater input!
As a matter of fact, we recently moved and I'm gonna get the old girl back out and stand her up for a bit!
I'm excited to do so since I've gained altitude and am away from the city finally!
Goal is, rebuilding the PDL4 for her new home!
By the way, I've ordered individual parts from Hygain for my P500 with good results!
Good luck friend!
http://www.mfjenterprises.com/
Reactions: Marconi
Good luck friend!
If I've done this right, here's a link to help!
http://www.hy-gain.com/Downloads/index.php?productid=SPT-500&filename=SPT-500.pdf&company=hygain
Good luck friend!
Thanks
Does anyone have the schematic for the old version, with the dimensions? I have an old P500 from back in the late 60's in a pile, I wanna rebuild it and stick it up on the top of my tower.
Dave
Dave
The 22' 9 1/2" antenna height is for a 23 channel radio. When using a 40 channel set the overall length to 22' 6 1/2"
  • hy-gain_500_penetrator_1975_early.pdf
Reactions: RT431
  • @ Wildcat27:
    63Sprint has left the room.
