Not sure if this has been covered but still figured it's worth contributing in it's own thread.
I am simply demonstrating this modification for educational purposes only!
Conversion to 11 meters is pretty simple but care is needed due to the proximity of wiring and connectors near the area being worked on.
On the channel selector board next to j4 you will find a solder blob that's jumping two pads. Simply remove the blob and voila you now have the 11 meter band.
Band A - HI is your cb band
Before conversion
After conversion
There you have it!
Before conversion
After conversion
There you have it!
