The factory power supply in that radio was suicidal. Typical failure was a shorted pass transistor in the regulator circuit. Would cause 22 Volts DC or more fed to the radio circuit board. Might want to check that before powering it up for longer than it takes to get a meter reading. Poofed audio chips are a typical result.
We remove the heavy copper and iron power transformer, rectifiers and filters. A chinesium switchmode "brick" power supply rated for 360 Watts will do the job and has both overvoltage and overcurrent protection.
Oh, and one other small detail. A fuse block should be added to put a fuse in line with the power wire feeding the circuit board. You wouldn't hook a 6-Amp mobile radio directly to a 30-Amp power supply with no fuse would you? That's what the factory sold you.
Makes life safer for the radio. If a final takes a dump, this minimizes the other parts that get overloaded and fail along with it.
