So much for resale value (TRS Challenger 1400).
TM86
Supporting Member
I Support WorldwideDX.com!
Jul 6, 2014
2,176
3,587
273
Payson, AZ
Grabbed this from the Bay of Fleas a while back.
If you look closely you may notice a dark streak down the face of the radio about where the squelch knob is. Turns out somebody had let something nasty drip on and run down from the top to the bottom. So I just had to clean it.
Yep, took the black right off. Only where the mystery goo was, but still. In addition to the squelch knob it also crossed the "Low" filter button. Which means it probably got inside as well.
Which it did.
It's not too bad, but I still have to more less remove the front of the radio to get rid of the rust, then paint what remains to prevent a repeat performance. There's also rust on the inside front of the bottom cover.
But no matter what I do, this thing will never have the value it could have had some previous owner not allowed the face to get eaten.
Which I guess means I'm free to get stupid with it since a simple restore is probably not in the cards anymore.
Sadly many radios probably fall in this category. Never know what is inside. (Better than a roach infested radio, but the roaches died 15+ years ago.) All you can do is just clean it up the best you can. Better than letting it rot away another 10+ years.
Yep. And I already dealt with a roach infested radio. Then there was the one that had been in a heavy smoker's home. Took leaving it in the garage for a month and several applications of Febreeze before I could even clean that one.
Anyways, progress of a sort.
Just hope I can bend the little metal tabs that hold the meters and clock back without breaking them when it comes time for reassembly.
Little bit of progress.
Wire brush removed most of the crud and rust. I'll hit it with some rust converter this weekend. Then I I'll have to pick a color to put on top of that.
I'd like to get the top and bottom covers stripped and done over with some hammer tone black, but I need to find someone with a booth for media blasting.
It lives!
Not sure why the clock is missing some segments. I'm hoping it's just some bad connections I can fix. If not, well, that's when things get interesting.
All three mode indicators work. RECEIVE light works. Meter lights work. No TX as far as I can tell, but I can hear the relay clicking. RX appears to be fine as far as being on frequency goes. No segments missing on the channel display. Even the little buttons to set the clock work.
Really, it's better than I was expecting.
PLL is a uPD2810 so no crazy frequency mods unless I want to go with a DDSVFO and maybe rewire the clarifier control to act as a RIT knob for that. Which I really don't right now. Maybe, if I manage to blow up the PLL during the planned recap.
