Palomar 225 blue label help
fastfreddie1269
New Member
Dec 9, 2025
29
3
3
59
I just picked up a blue label Palomar 225 with 2 455's (see pics). I am wondering if it's possible to eliminate the delay when keying it up, and when were these made, if they are "good" amps (better than black label 225's?), and how much they should actually put out with a proper "low dead key"?
Reactions: doffo
Pretty sure the sideband-delay capacitor is the small dark-blue electrolytic seen just to the left of the big bare-wire coil between the coax sockets.
Taking it loose permanently would involve clipping it loose where it stands. But to turn the delay back on would require a switch and a working capacitor. Would be a bit tricky to do without removing the pc board from the heat sink.
Reactions: doffo
Thanks! I have no problem with pulling the PC board out and desoldering that cap! I want to clean the flux off it anyway and put fresh thermo paste on the power transistors.
Great little amp for SSB use. Bought one new in 1997 from Thomas Distributing for $89 lol. I'd buy 50 at that price today. Mine had the SRF3749 finals. Just don't overdrive it and if your a long talker add a fan on the top. Nice clean looking amp.
Reactions: doffo
That's interesting. Thanks for your response. This one has a pair of MRF455's, do you suppose the ones you mentioned with the SRF3749's are better, or more powerful? I gave a hundred dollar bill for it, didn't even try to talk the guy down. Excited to get variable dead key installed on my radio so I can run it! I also have a "black label" version of it (also with 2 455's) that I gave $20 for and included an old Philippines Uniden PC68XL & astatic mic. The black label amp has a badly burned resistor & some wonky wiring. It doesn't work.
The 454,455, and 3749 were all very very similar. The amp builders of that day would purchase these finals in large lots, they would build the same amp with any of the above finals. There would be no real functional difference. (note they would use the same for both finals, no running one 454 and one 3749) At some point the MRF and SRF finals became harder to get and it seems the SD1446 became very popular in many amplifiers.
  • @ heartbreaker3473:
