Echo Board Question
BigMike357
Apr 2, 2020
36
7
18
47
I have an older Galaxy Clone echo board. It is installed but my question
is why is the PTT not hooked up? Is it not needed? Also why are the input
and output from mic audio on the echo board soldered to the same pin
as audio instead of breaking the connection?
Thanks,
Big Mike in WV
The side-by-side 3-pin headers have the PTT pins tied from one header to the other. The echo board just passes the PTT line from the mike socket through the echo board to the main pc board. It's not connected inside the echo board.
A digital echo, however is different. The PTT line will serve to erase the digital memory when you unkey. If it didn't the audio from just before you unkeyed last time could still be repeating. Best if the echo board is quiet when you key the mike. But the old analog echo has no need for this.
