What's the purpose of the extra set of plates on this Air Var Cap? Johnson 169-25
Naysayer
Solder Balls
I Support WorldwideDX.com!
Mar 6, 2020
361
271
New York
1778023685414.png I saw this on eBay Seller wrote it came from a Viking Matchbox Tuner. neil, NYC
It's just 2 more caps? Yet, they are inverse-synched to the primary 2 sections. My small brain couldn't grasp the use of such an piece.
Was considering it to replace my Load cap and remove the extra hardware. (1 I have now is too narrow range) but could not find specs for a Johnson 169-25. Do the Johnson stock numbers translate into the C specs somehow?
Same Cap!
"it does serve to improve feed-line balance and reduce the potential for feed-line radiation. Most coax systems are already referenced to ground via chassis ground or shield grounding at the point where the coax enters the shack. It is a design form which is only important in terms of using balanced line; a reference to ground for a normally floating balanced line" There I go. Thank you Sunbulls
