My prized Galaxy 2100 frequency counter went out. Radio works fine though. I replaced all electrolytics, even scraped out the dried up glue. The rest of the radio also had all the electrolytics replaced. Freq counter board # EPT210010A. Radio stamped Taiwan. On the counter board, 3.2768mhz xtal and 10.6975 mhz xtal oscillating. 8 volt regulator good. Tuning the coil next to the 10.6975 xtal displays (on the freq counter) either 10.695, 21.390, or 32.085. Where do I go from here? Per the schematic, looks like there is 1 wire on the counter that takes input from the main board. Anyone know what that signal is?
Thank you.
Thank you.
