What Astatic model is this?
Tokin
The Man With No Shoes
Oct 31, 2019
1,700
3,079
273
59
SandBox
The back which doesn't fit right says 555. The problem is this back uses the old style star shaped removable stem and the mic has a stem built in the the potentiometer and the diameter is larger than the hole. Also the mic grill is convex where i thought the 555 and 557 were concave.
Im guessing with out the proper back the only way to confirm the model is by the switch wiring? I believe this is an M6, maybe first gen judging by the 7.5v battery use but can't find an example with a back that will fit properly to confirm.
Any help would be appreciated, thank you.20260923_220000.jpg20260923_220049.jpg20260923_222311.jpg20260923_222335.jpg
D104-M6 Minuteman II
I thought that too. Is this a newer model with a fixed potentiometer stem? All the minuteman 2 examples i see have the white plastic star like shaped one piece knob and shaft and astatic is raised lettering on the face. This one is a bit different with the printed nameplate and a 2 piece stem and knob but still using the 7v battery.
Yes
Te one you have, has a newer logo sticker on the front. It could also be a TMD-107E. Hard to say, without the proper rear cover. If I had the mic here in front of me, maybe I could tell, by looking at the cartridge, PCB etc.
Reactions: Tokin
I took a closer look at the D104M/6 and TMD-107. There is a distinct difference, in the front grills. The TMD-107, has a wider spacing, between the interlacing.
This mic is a D104M/6. Minuteman II
