Jc penney 6246
k9fon12374
May 9, 2025
27
52
I got one plus a k 40 and a power supply for 15.00 yesterday. Im trying to find any vrs to turn the ssb and am up a tad, but nothing to be found. .
My Sams index says it's the same as the Sears in CB-254...
I found the vrs.. Am seems pretty good, but ssb im only getting about 6 to 8 out. Should be a tad more since its a 40 ch.
Screenshot of the transmitter alignment section of CB254 that Dan shared in post #274 of the Sams thread.
One thing that seems kinda odd to me is the order in which the adjustments are listed. The ALC is set to 12w in step 3, and then in the last step, it says turn ALC to minimum and adjust the cans.
I am not familiar with that radio, but I would sure think that the ALC setting should come after the cans are peaked.
I have the Sears version of this radio, The VCO loop and the oscillators are giving me a hard time so I had to park it for a while, to ease my headache. Model # 934.38260700.
After peaking 204 turn off the tone and double check the carrier balance (RT & CT201) then back to using a continuos tone, when you get to T402 and T403 turn the tone/mic input level down until the wattage drops to 1 or 2 watts and adjust them each a little at a time to get the highest low watt peak. Then turn it back up to normal and continue. And like Brandon says Redoo RT402 (ALC) at the end to your liking.
I usualy set ALC with the 2 tone and a scope till the tops of the "eggs" start to flatten or stretch a little, then back it off to round them out again.
Reactions: brandon7861
