Sidewinder amps
If anyone gets some info I would be intrested as well. been out of the game for 20 years.Just getting back in and I am lost so much has changed for the better. the equiptment is better and more powerful and the information avalable is mind boggeling.
Hey 357. Your 150 looks good at 200 watts. Mine is a 350 doing 380/400 watts on test. It's a 1x4 with sd1076 70/80 watt transistors. What is the transistor numbers for your unit?
what kind of power does the 350 take to run? I just came into possession of one and looking to see what it is going to take to power it up?
I also have the 350. Do I have to do anything differently because of the floating ground? Any documentation would be great to have!
I have never seen any paper work for the Hayden amps.
There's some information on the forum in this thread with some history of the builders...
Reactions: 9633
