The linear I have is a TX-600. Based on what everyone says here, I will be good to go with a 100 amp supply. I want to run this on my base. I have a Tekpower 50 amp supply that I bought here. If I buy another one, can I stack them? That is, can I parallel the outputs to get 100 amp capacity without frying anything??? Do I need isolation diodes??? The supply is good quality. 0-24 vdc, 50 amp continuous, overload , current sense, blah, blah, blah. I can afford another 50 , but a 100 is kinda out of my $$$ range. Will this work or will I be up in smoke?
- 399
