10 turn Clarifier Pot
Sammitch
Oct 20, 2014
31
76
Hey all,
Does anyone know where I can purchase a 10 turn pot for the clarifier in my cobra 148gtl, side mount mic?
I have found all kinds of them, but would like a splined shaft so I can keep the original knob.
I know it is 20k pot, but everything I find is either smooth shaft or flat on one side for a set screw.
The radio was modded when I bought it new in 1985, but the stock clarifier is just too touchy. Just trying to find one with a splined shaft.
Thanks, sammitch
Hey all,
Thanks, sammitch
Most of these come from china for $4 (some cb shops charge you $40 to add this option) but unfortunately you have to drill out the knob. One ass even made a video with showing off the wobbly know as he turns it. LOL
Reactions: 543_Dallas
Hey all,
Thanks, sammitch
That's going to be a lot fun
Try to revert the modification and get a small range +2 or -2 Khz is all you really need with the original potentiometer
More range makes the radio very unstable,frequency drift,etc.
There are channel kit's with IC's to get 5Khz and 10Khz up or down
PLL-Module without LED-function (for AM/SSB-radios)
Pincompatible replacementfor original PLL, for Selfinstallation *
High quality Motorola PLL onboard
Up to 4 bands in international grid
For MB8719 / PLL02A / CCI3001 / LC7120 / LC7131 / uPD28xx
● Also available for uPD858 as additional module
Additional functions like +10kHz, +5kHz, UK band etc.
Hope this helps
Andy
Reactions: LeapFrog
hi Sammitch,
you aren't going to find one with a splined shaft. if you do, make sure you tell us, as we will all be buying some. LOL
you will have to drill out a knob to 1/4".
best to use a drill press for this, as any hand drilling is just asking for a wobbly "snake radios" type of operation.
