10m twin lead j pole questions... Problems
mr_fx
Oct 8, 2011
1,536
172
173
Kansas City
OK so I tried building a 300 ohm twin lead j pole...
I followed the directions for 450 ohm window line seen here
http://www.qsl.net/dk7zb/J_Pole/wiremanjpole.htm
I used some random 300 ohm twin lead I had laying around (the black hard plastic stuff with windows through it) for the matching section,
and 18g solid insulated "underground" wire for the Top section...
I did I quick test... But I could only get the bottom of the antenna 1 foot off the ground (I'm lazy)
The results are as follows:
Impedance: 57
Reactance: 7
Swr: 1.1
Frequency: 25.430mhz
2.0 swr range: +/- 650k
My target frequency was 28.500mhz
So my question is is the fact that I have mounted the antenna so close to ground the problem? Has this detuned the antenna? It seems like that is an awful lot of Detuning
Or is it possible that I need to adjust the length of the main elements?
Or do I need to adjust the length of the matching element?
Or is everything just too long because of velocity factors?
Or do I need to adjust the feed point location any ideas?
1/4 wave matching section will have to be adjusted for the Velocity factor of the cable you are using. If you cant find it . Sweep it with a analyzer or dip meter.Original article was using .905 .Your cable is obviously lower The 1 ft off the ground is most likely pulling it a little low as well.
