148f hybrid what's required
711
Mar 22, 2008
359
437
i have a couple of 148s I'd like to add a frequency display to, like a 148f. I got an 88 front and a 148f front. I also have the counter board from a 148f. Besides the fact of rerouting the push button wires. What's needed to get the counter working right?
You need the metal plate that's behind the faceplate, as well as the 6 pushbutton switches. Other than that it should be good to go.
~Cheers~
http://www.radiomods.co.nz/galaxyfc347_texasrangerfc390mods.html
This should give more light to the situation. I believe the the jumper is for a 10.695 IF or 7.8 IF selection.
Those type of freq counters don't take into account the IF hence the jumper. So there is a chance the counter would be not accurately displaying the "overall" freq of the radio if your IF's aren't spot on.
CBPhreaker
I will give it a shot, just been lazy to get it going with he other projects I got going on. On a Side note Phreaker, I do want to get back to low level modulating my 148. I also need to solidify the precision diode detector.
