1994 Philippine glue…
Dirty Duck
Mar 29, 2025
57
9
18
30
I’m working on a pc 76 still. I got rid of almost all the glue and needed to switch out a transistor.
2 of the non corroded prongs came free but the corroded one is stuck in the board.
Is there a way to dissolve just a little cement glue?
If that's the corrosive "Sonybond" brown crud, a little acetone should soften it up. I use "GC Radio-TV Service Solvent", but really even nail polish remover should do the trick.
I usually use a Q-tip (or generic equivalent) to dab the solvent onto the glue and then wait a few minutes. Then I get in there with a dental pick and start lightly scraping.
If it's gotten brittle I'll just go in with the pick and break it up.
If it's some other kind of glue then disregard.
